udf problem
Old   April 14, 2006, 10:48
Default udf problem
Ankit Tayal
I am running a simulation in which the heat flux from the wall to the fluid flowing inteh channel varies linearly with the x co ordiante (independant of the other co ordiantes) i wrote the udf for it but it gives this error every time i run it.
chip-exec: heat_flux: argument 1: incorrect type (31): int expectedchip-exec: heat_flux: argument 2: incorrect type (5): pointer expectedchip-exec: heat_flux: argument 3: incorrect type (-842150451): int expected Error: FLUENT received fatal signal (ACCESS_VIOLATION) 1. Note exact events leading to error. 2. Save case/data under new name. 3. Exit program and restart to continue. 4. Report error to your distributor. Error Object: ()
my udf program is as folows
#include<udf.h> #DEFINE C1 39682.5 #DEFINE C2 2645502.646
DEFINE_PROFILE( heat_flux,thread,i) { real pos_vec[ND_ND]; real x; face_t f; begin_f_loop(f,thread) { F_CENTROID(pos_vec,f,thread); x=pos_vec[1]; F_PROFILE(f,thread,i)=C1 - C2*x; } end_f_loop(f,thread) }
please help me thanks in advance
ATTN ALL: SOLUTON TO UDF COMPILE PROBLEM Rizwan Fluent UDF and Scheme Programming 40 March 18, 2018 06:05
Problem with my udf july Fluent UDF and Scheme Programming 3 June 20, 2010 06:56
UDF problem mansha goraya FLUENT 0 October 29, 2007 00:31
udf compiling problem akr FLUENT 3 August 22, 2007 07:14
UDF problem chiseung FLUENT 4 January 10, 2002 09:58
