mixing plan problem
Old   April 29, 2006, 05:02
Default mixing plan problem
ravindra bankar
sir/madam,
i am student of Mtech turbomachines from s.v.N.I.T. surat, Gurat state, India. I am doing my Mtech project work and i have to do analysis of axial flow compressor in Fluent 6.2. Problem : I have created inlet flow and exit flow domain and blade domain with blade at Center both for rotor and stator. As my rotor is highly twisted, for stage analysis i have taken two blade domain and one stator domain. I have generated mesh and transport to fluent 6.2 all boundary condition i have given properly. mixing plan generated . here only i am facing problem mixing plan is generated but it is not exchanging temperature from rotor to stator and back . i am getting all relative vectors in direction of flow . i am getting mass flow out of stator . upto rotor outlet rise in total temperature is there. At stator inlet it is taking temperature as 303K what i have give at inlet of rotor. rotor outlet also i am getting same temperature . due to this i am unable to get efficiency in turbo report. also as back pressure (static) rising mass flow reduces but Pressure does not increases. so please help me in this regard so that i can solve this proble with in small time to complet my project work . thanking you
ravindra bankar
Old   May 11, 2006, 06:43
Default Re: mixing plan problem
sam
why r u using two sectors of rotor ???????????????? . u can use one of each. that is wat called mixing plane.
plz be touch for more discussion
Old   May 12, 2006, 03:41
ravindra
sir, sam thanks for support. i have slove my problem by using two stator and single rotor. thanking you. by ravindra
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 05:59
Mixing Station with high swirl AleDR FLUENT 23 November 5, 2009 11:49
STARCD: combustion problem involving multi-component mixing Paolo STAR-CD 0 October 19, 2009 11:54
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
multiphase mixing Problem with MRF model in MixSim Srinivas FLUENT 0 October 17, 2005 06:35
