initial guess 6DOF-solver
Old   May 3, 2006, 07:31
Default initial guess 6DOF-solver
Astrid
I would like to calculate the track of an object in a tube using the 6DOF-solver. My problem is that I need an good intial guess from a situation in which the object already has a velocity.
The first step I did was to calculate the flow field in the pipe without object. The second step was to interpolate this velocity field on the grid with object. I have managed to do this but then the object still has velocity zero. How can I get a decent velocity here?
Regards, Astrid
Floating point exception error Alan OpenFOAM Running, Solving & CFD 11 July 1, 2021 21:51
Low Mach number Compressible jet flow using LES ankgupta8um OpenFOAM Running, Solving & CFD 7 January 15, 2011 13:38
ForcesCoeffs ronaldo OpenFOAM 4 September 14, 2009 07:11
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
