UDF source folder dependence???
Old   May 12, 2006, 00:38
Default UDF source folder dependence???
Sasha
Hi. I'm trying to read the UDF into Fluent. When reading it interpreted from the Fluent.inc folder - everything is working fine. On the other hand, I can't do it when the case and the .c files are in some other than Fluent.inc folder. Please help me with this. Thanks a lot.
Old   May 15, 2006, 10:51
Default Re: UDF source folder dependence???
AdN
You have to put a file named UDF (or everything else) in the root of your hard disk. After your can save your case file everywhere on your HD. Normally it will work if you want to interpret your udf function
Hope it wil work
Old   May 16, 2006, 04:10
Sasha
Thankx, I'll try this later today. Sasha
Old   May 16, 2006, 04:33
AdN
I make az little mistake, You have to create a folder (and not a file) named "UDF" on the root of HD (ex: c:/UDF), and after you save your .c function in it. and your case file anywhere...
HELP! adding a mass source to VOF eqn. by UDF??? ROOZBEH FLUENT 5 December 3, 2016 17:53
UDF Source Term Units? Brian FLUENT 1 October 24, 2005 09:15
help on UDF mass source shao1 FLUENT 2 July 11, 2002 20:36
UDFs for Scalar Eqn - Fluid/Solid HT Greg Perkins FLUENT 0 October 13, 2000 23:03
UDFs for Scalar Eqn - Fluid/Solid HT Greg Perkins FLUENT 0 October 11, 2000 03:43
