How to set a free slip boundary?
Old   May 22, 2006, 08:21
Default How to set a free slip boundary?
J.Gimbun
Hi Fluent user, I am simulating a multiphase (air-water) system using DPM with water as a primary phase. Is that possible to set a free slip boundary between air and wall? I couldn't find the way to do it and currently my primary phase is set as 'no slip' boundary with the wall. Thanks in advance.
Old   May 22, 2006, 12:24
Default Re: How to set a free slip boundary?
Siddharth Khowala
hi If u are using the fluent version 6.2 thr is an option in wall boundary condition which asks u to mention the specularity coefficient.It is through this option that u can specify the slip wall condition,The previous versions dont have it, In that case u would have to write an UDF to use the slip condition. u may ask the fluent experts as to how to set up the UDF in previous versions.
regards
Old   May 22, 2006, 12:50
K.Baker
Hi may your case was similar to my since i also have (air-water) flow in a pipe can you tell me please what did you mean by by DPM and are you used the VOF model to represent the phases and if you used it how can you represent them by it. Please tell me if you have the same of case we can cooperate together and about your question you can set the no slip boundary to the wall by un choosing moving wall in the wall BC. If you have some idea about my case you also can contact me by the email khalidb77@yahoo.co.uk. Sincerly Khalid
Old   May 23, 2006, 03:17
J.Gimbun
Thanks all for the reply, I'm thinking of using the two fluid model instead. Hi Khalid I've use VOF before for some flow in a stationary boundary but in my case now I'm not interested to know the fluid volume or fluid level, but I'm want to see the gas dispersion in mixing tank. I have some success to run the VOF before, in which I applied some pressurise air to remove water from the micropore. This is very straightforward actually. Cheers,
Old   May 23, 2006, 03:25
K.Baker
Thanks to the replay if you used the VOF model before can you assist me to how can i model a two phase flow in a pipe by using this model in which i want water be separated from air layer. Khalid
Old   May 23, 2006, 09:01
Krishna Podila
Dr Gimbun and Mr. Khalid , you cannot have free slip boundary condition in Fluent. You can specisy the shear rate to be zero at the wall and it may work like free slip but not the correct way to handle it. I am aware in CFX related journal article they do talk about free slip BC near the wall for pipe flows. They would also mention about wall forces. However you cannot alo have wall forces in Fluent even using UDF. Let me know what kind of pipe you guys are working on. Is it bubbly flow? KP
Old   May 23, 2006, 10:13
J.Gimbun
Hi Krishna, I know very well that we can set easily either no slip or free slip in CFX because I have try it some time ago. You are correct, in Fluent setting shear rate = 0 in Fluent didn't exactly similar with 'free slip' boundary condition. I'm not working on flow in pipe (like Khalid) I'm working on gas dispersion in stirred tank. I'm planning to do PBM on that later on. Thanks for a good discussion.
Old   May 24, 2006, 10:11
K.Baker
Dear Krishna :‎ I have no problem in my case to set free slip boundary , but I have a problem in represent ‎a two phase (air-water) flow using the VOF model into a pipe, can you guide me to how ‎can I did that please.‎ Thanks Khalid
Old   May 24, 2006, 11:44
Krishna Podila
I work on E-E. There we set sing define-phases so on and so forth. KP
Old   May 25, 2006, 03:17
K.Baker
Dear Krishna what did you mean by E-E are you work in single phase flow. Khalid
Old   May 25, 2006, 08:02
  #11
Krishna Podila
eulerian-eulerian
Domain Imbalance HMR CFX 5 October 10, 2016 05:57
Free slip and no slip. Yung Phoenics 3 March 2, 2006 11:04
Free slip and no slip. Yung Siemens 0 February 4, 2006 10:37
Free slip and no slip. yung FLUENT 0 February 4, 2006 10:26
slip velocity on boundary (V.P.M) Lee, Juhee Main CFD Forum 3 October 22, 1998 15:30
