transparent isosurface
Old   May 23, 2006, 08:30
Default transparent isosurface
mateus
Hi!
Is it possible to make an isosurface transparent in fluent? Something simmilar to what you can do with any wall (Display-scene-display-transparency)...
I donīt know why it doesnt work with other isosurveces (for example with volume fraction).
Any help is greatelly appriciated, by MATEUS
Old   May 23, 2006, 08:42
Default Re: transparent isosurface
Mark
Yes, you do it exactly as you would a wall.
Old   May 24, 2006, 01:02
mateus
I tried but it doesn't work...any ideas?
Thanks MATEUS
Old   May 24, 2006, 01:58
mAx
I assume it doesn't work on your active window. You should apply the transparency, and re-display what you want. should be then ok I have also the same problem with surface transparency
How to get a selected part to be non- transparent? Chenthu STAR-CCM+ 2 January 25, 2011 08:29
making light fluid transparent or see-through c-dot Siemens 4 November 21, 2007 10:32
volume and mass exist in isosurface in CFX eslam CFX 2 June 13, 2007 06:26
Can Tecplot calculate isosurface area alon axis x? leaf Tecplot 0 May 21, 2007 12:20
how to export x- and y-axis of isosurface ? Tom CFX 6 May 31, 2006 13:19
