Coupled solution
Old   May 24, 2006, 07:26
Default Coupled solution
Renaud
Hi, I ran some test with the segragated solver with good results. Now I would like to run the simulation with the coupled solver (High speeds are involved) and the solution doesn't converge, the residuals increase and I don't know what to do considering that the mesh was efficient before.
Thanks, Renaud
Old   May 24, 2006, 08:58
Default Re: Coupled solution *NM*
ahad_abedini
Old   May 24, 2006, 09:24
Luca
Hi! What range of Mach number are you considering? I discovered that if you have a good grid there's no problem in usign the segregated for high mach numbers. Luca
Old   May 24, 2006, 10:39
Renaud
I think about Mach 2 or 3 at most. But as I'm looking for a mass flow rate I think that as soon as you take into consideration the compresibility the result will be different. Thanks for your help anyway. Does anyone have a clue?
Exact solution of Burgers equation mcaro Main CFD Forum 3 January 25, 2011 06:46
How to get the solution of last time step? lzgwhy Fluent UDF and Scheme Programming 0 September 15, 2010 22:23
Integration along a line during solution DaRumpel CFX 16 September 2, 2010 11:17
CFX-ANSYS coupled solution Wenca CFX 3 December 23, 2004 21:51
Solver Equations Carola CFX 9 August 12, 2003 08:27
