hi all , can you pls give me some suggestion or link to a website which describes the difference b/w a good mesh and a bad one. pls help its urgent....
is the mesh in the following link good enought o solve for the flow
www.home.iitk.ac.in/~himan regards Himanshu |
Hi Himanshu, in GAMBIT you can check your mesh for the worst element. It should be not too close to 1 (0.6 or below should be perfect). Furthermore, the cells should be longer than wide (in flow direction). Unfortunatelly, I couldnt check your mesh. Claud
select the quality check button -> check the element type 2D/3D -> go for Range option -> then go for skewness check. you can easily see the mesh values for each mesh volume. i hope this will help you. bye san |
Gambit problems | Althea | FLUENT | 22 | January 4, 2017 03:19 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
good mesh | RKT | Main CFD Forum | 1 | October 25, 2008 03:50 |
How to control Minximum mesh space? | hung | FLUENT | 7 | April 18, 2005 09:38 |
Mesh for 3 dim Geometry | Phil | FLUENT | 9 | July 12, 2000 04:39 |
