How to simulate valve with pressure BC?
Old   June 20, 2006, 01:27
Default How to simulate valve with pressure BC?
Luk
Hi all, I have following problem. The geometry is very simple: air enters the pipe from one side under pressure. On the other side there is valve: the valve could be in one of two positions: "closed" where no flow is possible (pipe closed from one side) and "opened" where sucking occurs through the valve. The valve opens and closes periodicaly. I am using UDF to represent changes of the valve state in time but I dont know how to simulated closed valve with pressure BC.
Any ideas? Luk
Old   June 20, 2006, 02:31
Default Re: How to simulate valve with pressure BC?
Gernot
Why donīt you change your pressure outlet to wall and backwards ?
Old   June 20, 2006, 03:46
Luk
Is it possible with UDF? I mean is it possible to periodicaly change type of BC for specified surface/face?
Old   June 20, 2006, 04:47
Gernot
I didnīt work much with UDFīs. But Iīm sure you can handle that with a journal file. The question is how often do you open and close?
Old   June 20, 2006, 06:12
Luk
About 100/sec. The size of the pipe is few cm in diameter and about 50cm length. Pressures are rather low.
Old   June 20, 2006, 06:46
Gernot
O.K., i tried some things. To change the boundary condition with a journal file is possible. To start the journal file with an execute-comand works too. So there is a posibility to automate the whole thing but itīs a long way.
Maybe someone else knows an alternative.
Old   June 20, 2006, 07:07
Luk
Dear Sir, Thanks for Your kind help! I'll try this solution today in few hours.
Luk
Old   June 20, 2006, 07:25
Gernot
last chance for me to help you is tomorrow, then Iīm on holiday for 2 weeks - Jippie!!!!
The execute comand to start the journal is easy :
file read-journal nameofjournal
the journal comands to switch from wall to pressure outlet :
define boundary-condition modify-zones zone-type ( ID number of your face you want to switch ) pressure-outlet ( or wall when you switch back )
but be careful the settings of your pressure outlet are set to the default values. you can change them with :
define boundary-condition pressure-outlet
good luck
Old   June 20, 2006, 08:06
Luk
I wish Your nice holydays! Could You be so kind and send me email for further contact: my address is Lukasz.Czopyk@ifj.edu.pl. I promise not to disturb Your free time anyway.
Luk
"Pressure Inlet" Boundary Setup Wijaya FLUENT 15 May 18, 2016 10:08
how to simulate pressure variation wrt time at outlet gyanesh FLUENT 4 April 21, 2011 03:42
How to simulate valve using pressure BC?? Luk_Fiz CFX 4 August 16, 2010 18:27
Does star cd takes reference pressure? monica Siemens 1 April 19, 2007 11:26
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 02:15
