January 14, 2014, 05:33 |
Error message when model as constant gas
Meimei Wang
Rep Power: 15 |
I'm modeling the 3D aircraft wing. But when I change the material from ideal gas to constant gas and deselect the energy equation, I got the error message as below. Updating solution at time level N... done. iter continuity x-velocity y-velocity z-velocity nut time/iter 24565 2.3463e-05 9.2823e-08 5.5400e-08 3.2518e-07 5.0943e-06 0:01:39 50 999999 (..\src\mpsystem.c@1172): mpt_read: failed: errno = 10054 999999: mpt_read: error: read failed trying to read 8 bytes: Invalid argument MPI Application rank 0 exited before MPI_Finalize() with status -1073741819 The fl process could not be started. Btw, I use SA model. And everything was normal when I run the simulation with ideal gas and clicking on the energy equation selection. May I ask what does the error message mean and how to model case in Fluent by constant gas?
Best regards, Meimei |
Ideal vs constant gas model | chris12345 | STAR-CCM+ | 1 | January 2, 2013 06:49 |
model the concentration of toxic gas in a building | lily | FLUENT | 1 | December 12, 2007 01:07 |
gas turbine combustor model - HELP! | Phil | FLUENT | 7 | May 2, 2007 06:40 |
gas turbine combustor model - HELP! | Phil | FLUENT | 2 | April 9, 2007 05:05 |
Shall I use ideal gas model or other? | summer | FLUENT | 6 | January 24, 2006 10:43 |
