Please I need help in defining an inlet that is fully in the fluid region and not on the boundary. Please if anyone has a detailed procedure, it would be greatly apreciated. Thanks in advance
How does this look like? It must be a boundary, at least a single line!? Or do you want to model a source in the fluid??
Thanks for the help. I have a tobe contains a series of Nozzles (300) with very small diameters (0.0013 in) that spray a gas insilde a vacuum chamber. The gas in coming through a tube to the Nozzle tube. Since it is impossible to model the actual geometry of the nozzle. I tried to model it as an inlet (face) that is totally inside the region. I guess this definition does not constitute a mass source. Please Help me with any suggestion. Regards
Internal Flow BCs for Compressible inlet flow | Katie | FLUENT | 2 | March 3, 2012 17:35 |
Setting dynamic pressure as the inlet BC | ruined | FLUENT | 1 | March 26, 2008 05:30 |
Setting static pressure as the inlet BC | ruined | FLUENT | 1 | March 21, 2008 14:57 |
Defining Duct Inlet Pressure Distribution? | Eric | FLUENT | 1 | February 8, 2008 16:50 |
transitional inlet boundary condition | kamp | CFX | 1 | June 21, 2006 11:08 |
