Hello everyone
I am using partially premixed combustion model with propane. My problem arises when I try to define critical strain rate to extinction g_cr=U^2/alpha, where U is laminar burning velocity and alpha is thermal diffusivity. Fluent compiles or interprets UDF without any problem (I tried both options). My "headache" starts when I hook UDF. Fluent gives following error: Error: FLUENT received fatal signal (ACCESS_VIOLATION) 1. Note exact events leading to error. 2. Save case/data under new name. 3. Exit program and restart to continue. 4. Report error to your distributor. Error Object: () Interrupting... Done. This is a very simple UDF: /************************************************** ********* strain1.c UDF for critical strain rate to extinction ************************************************** *********/ #include "udf.h" #include "sg_mem.h" DEFINE_PROPERTY(critical_strain_rate,c,t) { real S_ext; real alpha_c; real u_lam = C_LAM_FLAME_SPEED(c,t); real k_c = C_K_L(c,t); real rho_c = C_R(c,t); real cp_c = C_CP(c,t); alpha_c = k_c/(rho_c*cp_c); S_ext = (u_lam*u_lam)/alpha_c; return S_ext; } I will appreciate for any hints and tips, how I could solve this problem. Thanks, Birute |
Ahmad
Rep Power: 17 ![]() |
This (too) late, this is not a fix. It's rather a conceptual matter. You need the "unburnt" thermal diffusivity for the expression of the critical rate of strain, that is you need to use the unburnt mixture properties. I wrote a UDF for that but I use mean mixture fraction polynomial curve fits to compute the unburnt thermal diffusivity (you can get these from Fluent). However, for some reason, it's not giving me what I expect. Did you manage to figure out how to do this eventually? Ace |
strain rate in UDF | Paulina | FLUENT | 11 | November 20, 2014 03:06 |
strain rate magnitude | ahmadbakri | STAR-CCM+ | 1 | June 3, 2010 13:03 |
UDF for the critical rate of strain. | cryogenicT | FLUENT | 0 | March 25, 2010 15:52 |
Strain rate. | MM? | Main CFD Forum | 1 | February 15, 2006 08:55 |
strain rate at arbitrary position in a cell | K. Kevala | FLUENT | 0 | February 4, 2004 17:14 |
