July 18, 2006, 12:07 |
granular flow
Hi, Ive got the following problem: I want to simulate the discharge of a hopper. I use the eulerian model with 2 phases (air and sand). I use also a 2d geometry designed and meshed with gambit. For BC I choose velocity inlet and pressure outlet. The flow should be gravity driven. The problem is, that the continuity does not converge!! Even if I try to get a solution with the unsteady simulation and realy small time steps. So what could be the problem here? And how can I make sure that just a wanted mass flow rate is taken out over the outlet? Because the real problem is solved with a screwconveyor. You see I'm new and not realy familiar with fluent yet. So please help me!!!
thanks |
July 19, 2006, 02:01 |
Re: granular flow
Hello Lydia
I'm a beginner so I don't know if I can help you but what I've seen is that there is a tutorial in www.fluentusers.com called using the eulerian multiphase model for Granular Flow. I did it and the two phases are water and sand. If you think it can help you have a look at it. |
July 19, 2006, 05:55 |
Re: granular flow
Thank you, I allready did this tutorial. But the difference is that there is no sand being discharged, just mixed. The first problem is that I do not get the solution to be converged, and the second one that i don't know how to specify the mass flow of sand at the outlet! I think both has something to do with my BC.
Help: apply B.C. in my granular flow model ? | Derek Jing | FLUENT | 1 | January 8, 2020 21:38 |
granular flow in the packed bed | VOG | FLUENT | 3 | June 7, 2007 15:40 |
Can 'shock waves' occur in viscous fluid flows? | diaw | Main CFD Forum | 104 | February 16, 2006 05:44 |
Help for granular flow simulation | Derek Jing | FLUENT | 0 | February 22, 2002 20:50 |
about granular flow model | daninwin | FLUENT | 0 | January 19, 2001 03:47 |
