Oscillating Residuals
Old   July 27, 2006, 08:34
Default Oscillating Residuals
Cairol
Hi all
I'm calculating a flow arround a Turbofans nacelle with mixing of core and bypass massflow using a 6 million nodes large grid. I have a converged solution for a freestream velocity of 50m/s and I now want to simulate the flow at different freestream velocities. Unfortunately the residuals for the velocities, energie and continuity are beginning to oscillate after 100 Iterations in between 1e-1 and 2e-1 with an amplitude of around 1e-1 and no convergence is reached.
My Simulation parameters are: Solver: Coupled explicit parallel on 8 cpus Gas: Ideal Gas Law for Compressible Flows Turbulence: Realizable k-eps CFL: 0.2
Maybe a multigrid can solve the problem??? Thanks for any suggestions.
Cairol
Old   July 27, 2006, 08:35
Default Re: Oscillating Residuals
Cairol
ups ...
Old   July 27, 2006, 10:13
esteve
What about changing the underelaxation parametres for velocity , If I were you I would decrease underrelax parametre 0.1 point and then see what happens
Old   July 31, 2006, 04:14
Cairol
Thanks for your Answers
I changed the under-relaxation parameter as well as the CFL-Number to 0.1 and used the coupled implicit solver instead of the explicit like Razvan suggested.
Unfortunately, the same oscillation appears after a 100 iterations.
Again, my simulation parameters are:
Solver: Coupled implicit parallel on 8 cpus
Turbulence: Realizable k-eps - first order upwind
CFL: 0.1
Massflows on inlets and outlets are more or less steady during the run, that is no oscillation appears in Massflow!
Cheers Cairol
Old   July 31, 2006, 09:34
Cairol
I took the segregated solver and .................................................. .................................................. ............... it is going to converge
Cheers
Cairol
Reason for oscillating residuals fayaazhussain Main CFD Forum 3 August 21, 2014 10:31
oscillating pressure residuals buoyant plume mabinty OpenFOAM Running, Solving & CFD 0 August 31, 2009 05:31
Oscillating Residuals Cairol FLUENT 1 July 28, 2006 01:47
Oscillating Residuals in Finer Mesh Case Jake FLUENT 3 June 16, 2005 09:34
oscillating residuals dave FLUENT 2 December 10, 2004 03:01
