Injection with unsteady flow
Old   August 4, 2006, 17:50
Default Injection with unsteady flow
Ali
Hi everybody.I have a question in using unsteady Particle with transient flow.if it is nessesary to solve the Continuous phase and then Coupled the calculations please tell me.
Old   August 7, 2006, 04:12
Default Re: Injection with unsteady flow
James
hi, i think you need to couple the solution as coupling ensures that you have mass transfer from your discrete phase to your continuous phase. You're are using the separated flow model approach and so your continuous phase is solved in the Eulerian framework and the discrete phase is solved using the Lagrangian formulation.
Check also the Fluent Manual for more info.
James
Particle Injection Mass Flow Rate and Position leonozx FLUENT 3 March 9, 2018 09:58
Unsteady Flow in FLUENT Vidya Raja FLUENT 0 November 1, 2005 17:54
Injection of partical into flow field M.Mahendran FLUENT 2 November 24, 2002 00:54
Unsteady Boundary Layer Flow Wen Long Main CFD Forum 0 July 29, 2002 23:08
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 21:31
