Boundary condition?
Old   August 25, 2006, 13:49
Default Boundary condition?
brian
I have a vertical heated pipe. I want to model a small suction tap in the side of the pipe, where i specify the flow rate at this tap. Then this fluid will be cooled down and injected back in the pipe a little above the suction tap. What boundary condition would i use for this suction tap, since i want to specify the flowrate for this internal section. (I need to inject the same fluid, because it is a diffusion problem, so I need the composition sucked out the same as put back in, but just lower temperature). Thanks in advance
Old   August 28, 2006, 08:04
Default Re: Boundary condition?
Jason
For compressible flow, you can use a mass flow inlet for both places. Or for the upper tap you could use a pressure outlet and give it a target mass flow rate.
For incompressible flow, you could calculate the average velocity at the two taps and apply velocity inlet BCs. You can also use the pressure outlet with a target mass flow in incompressible flow.
Hope this helps, and good luck, Jason
Domain Imbalance HMR CFX 5 October 10, 2016 05:57
Boundary Conditions Thomas P. Abraham Main CFD Forum 20 July 7, 2013 05:05
Setting outlet Pressure boundary condition using CAFFA code Mukund Pondkule Main CFD Forum 0 March 16, 2011 03:23
How exactly the "pressure outlet" bdry condition compute properties on the boundary? yating9901 FLUENT 3 June 28, 2010 12:26
How to set boundary condition in Fluent for the fo Peiyong FLUENT 1 November 10, 2006 11:44
