enhanced wall treatment
Old   August 26, 2006, 05:19
Default enhanced wall treatment
saeed
Dear users I'm simulating a closed cavity with Flunt 6 .. Realizable... but I dont know what wall function i should use for modeling it . my problem have 2 walls with heat flux and i'm validating with a paper written by Kenjeres ... so i should solve my problem with high accuracy .. I search help contents of Fluent but .. there is;nt any subject about enhanced wall treatment .. If its possible fou you please send me some information about it tanks...saeed
Old   August 29, 2006, 11:19
Default Re: enhanced wall treatment
Evan Rosenbaum
The enhanced wall treatment is nothing more than stacking cells against the walls to resulve the boundary later. Put a bunch of cells near the walls and solve. Then check y+. If y+ is about 1, your OK. For y+ >> 1 add cells near the wall. For y+ << 1, reduce the number of cells.
Old   August 30, 2006, 03:58
Albert F.
I thought that if the y+ was <<1 it was ok, wasn't it? Lower y+ you have better the results will be. Is this false?
Old   August 31, 2006, 11:47
Evan Rosenbaum
Yeah, my mistake. You can't have too low a y+.
Old   September 5, 2006, 04:44
Albert F.
Do you know how the results are affected by imposing a wrong y+? I mean If what I want to know is the temperature distribution along a wall a wrong y+ can vary the results severly? Do you trust in an other viscosity model?
Old   September 6, 2006, 11:38
Evan Rosenbaum
You cannot have multiple layers of elements all using the log law. The wall function would be applied to the first one only, even through others will be in the boundary layer. Thus, the boundary layer thickness would be too low. Switch to enhanced wall treatment of the y+ is too small for standard wall functions.
It is an extreme generalization (with plenty of exceptions) that you probably should not use standard wall functions when wall flows are critical. So, for the flow in a large room, wall functions are usually OK. For flow between two closely spaced plates, the usually are not OK.
Very technical question about solving wall boundary layer ... jlb001 FLUENT 6 December 27, 2014 05:56
Near Wall treatment sven OpenFOAM 1 September 13, 2009 20:57
Enhanced wall treatment with user-defined mu_t tstorm FLUENT 0 August 20, 2009 13:05
LES wall treatment Valerio FLUENT 0 April 26, 2008 07:12
help on wall treatment zwdi FLUENT 2 December 6, 2004 12:45
