I have two volumes which share a common face. When I copy the two volumes together to another location, each is copied separately and there is no longer a common face for the two copied volumes.
Is there a workaround for this? |
HI,
How did you create the first part. i presume you must have create a block and split that using a surface. when you copy that they are two volumes with two individual faces. Recreate the volume in the new location using surfaces. Regards Rajit |
channelFoam for a 3D pipe | AlmostSurelyRob | OpenFOAM | 3 | June 24, 2011 13:06 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
Gambit: Volume Meshing | fluentnoob | ANSYS Meshing & Geometry | 4 | May 20, 2009 05:21 |
Connectivity data in GAMBIT | Rajveer Kaur | FLUENT | 3 | December 14, 2007 22:09 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
