September 7, 2006, 06:01 |
low-re-ke-model
hi i have a problem with using UDF available in the following site http://www.stanford.edu/class/me469b...ing.pdf#search=%22low%20re%20ke%20model%2Budf%22 this UDF is for low-reynolds number-ke model by using scalar equaitons by deactivating the k and e equations. when i compiled the udf its getting complied but when i am initialising the velocity inlet, i am getting fatal error. i dont know the reason why i am getting this fatal error. pls can anybody try it out and tell me the solution. thanks for ur patience.
September 7, 2006, 09:15 |
Re: low-re-ke-model
have you enabled all the UDS and UDM memory slots in the solver?
Also, the Low Re k-e model is already available in Fluent but it has to be enabled using the text user interface. |
September 7, 2006, 10:24 |
Re: low-re-ke-model
thanks for reply i enabled all UDS in the solver. yah i know that low-re-ke model is available in fluent. but i want to try with UDFS and compare the results with other models
Use of k-epsilon and k-omega Models | Jade M | Main CFD Forum | 40 | January 27, 2023 07:18 |
Low Reynolds k-epsilon model | YJZ | ANSYS | 1 | August 20, 2010 13:57 |
Turbulence Model for low Reynolds Number | Muhammad Shakaib | Main CFD Forum | 2 | July 3, 2006 15:42 |
UPWIND-BIASED and Low Re K-Epsilon Model | Valdemir G. Ferreira | Main CFD Forum | 5 | June 19, 2000 23:13 |
