Dynamic Meshing - contact
Old   September 11, 2006, 15:08
Default Dynamic Meshing - contact
philip
I am working on a problem where I need to have an object, which is influenced by the flow using the 6 DOF solver, which will come into contact with another surface. I have been having issues with negative volumes which seem insurmountable using an unstructured grid. Anyone have any experience with this? Is is posible with an unstructured mesh?
Any feedback at all would be greatly appreciated.
-Philip-
Old   September 11, 2006, 15:47
Default Re: Dynamic Meshing - contact
philip
In the interim I've tried simulating a block falling onto a surface from a considerable height. I used an unstructured mesh and was able to preview the remeshing up until the block was in very close proximity to the surface. Then, as encountered before, negative volumes were created. It seems as though it might be impossible?
Old   September 13, 2006, 12:05
Default ANYONE AT ALL???
philip
Might anyone have any experience with a similar problem? I've tried reducing the mesh size and time step together and independently but invariably, as the two surfaces come into very close proximity, negative volumes are created by fluent.
Thanks a bunch.
Old   September 13, 2006, 12:30
Default Re: ANYONE AT ALL???
Wick
I don't think it's possible to ever get complete contact between the two surfaces using Fluent's dynamic mesh. The best you can hope for is to do what you've been doing and refining the grid and timestep. This will get the objects close but they'll never touch.
That's been my experience, at least. You might want to try using a sliding mesh with layering. Read through the fluent help manual and they might have something on it this problem.
Dynamic contact angle rmousavibt Fluent UDF and Scheme Programming 12 October 31, 2021 22:38
Dynamic mesh in Fluent to study tire in contact with road surface lihuang FLUENT 10 March 8, 2011 10:21
[ICEM] Meshing Contact Surfaces sandeep_tu ANSYS Meshing & Geometry 0 October 20, 2010 14:00
[GAMBIT] Dynamic Meshing of a combustion chamber donarundas ANSYS Meshing & Geometry 1 December 2, 2009 07:13
Theoretical background of formula for dynamic contact angle in interfoam sebastian_vogl OpenFOAM Running, Solving & CFD 3 June 22, 2009 12:25
