memory problem
Old   October 1, 2006, 03:59
Default memory problem
Matt
Hi everyone:
fluent stops the run and am receiving message below
Warning: ST_Malloc: out of memory.malloc_storage: unable to malloc pp, size 23537728, t 12, myid 1000000.
what is this migth be?
Old   October 1, 2006, 18:24
Default Re: memory problem
Ahmed
Malloc = Memory Allocation function. The C language standard library functions is explained in many books on the C language. Decrease the number of cells, increase the RAM, use the LINUX/UNIX operating system (if you are using windows), if your computer file system is FAT32 reformat to NTFS,..you have many choices, select the most appropriate to your budget and Good Luck
Memory storage problem IBM-machine, xlf compiler abelme Hardware 0 April 21, 2011 08:16
combustion problem mcnair CFX 9 March 22, 2011 14:06
Fluent Parallel Memory Usage David Christopher FLUENT 1 March 3, 2011 02:20
RAM memory problem alpha Main CFD Forum 8 February 12, 2008 11:07
"Memory too low" problem with Fluent HELP NEEDED Amr FLUENT 6 May 8, 2006 12:06
