October 18, 2006, 10:38 |
periodic condition at parallel solver
Dear Fluent users,
I am simulating water flow in rectangular duct with periodic B.C. at inlet & outlet. If I read the grid in Fluent6.2 on single cpu, grid check command gives no errors. On the other hand if i read same grid using 4cpu parallel machine, grid check gives warning and fails. The printed warning is "incorrect face count". I will be thankful if any of you can tell me the solution to this problem. Thanks Amer |
October 18, 2006, 12:20 |
Re: periodic condition at parallel solver
Don't setup your periodic geometry in parallel if you can help it. I don't know if they fixed this problem in 6.3, but its a common problem in 6.2 (and most earlier releases I believe). It has to do with how the periodic boundaries are sent out to the different nodes. Sometimes it'll work, but most times it won't.
Setup your geometry on the single machine (I recommend doing BCs, models, monitors, etc... everything so that all you have to do when you read it later is initialize and run), then go to Parallel->Partition and define how you want to partition your grid (usually I use Principle Axis and only change the number of partitions I plan on using... I leave everything else the same, but you can play around with the settings to try to improve the partitioning for your particular problem). Then write the case. Once you have a partitioned case written, you can read it into a parallel Fluent process and you should be good to go. Hope this helps, and good luck, Jason |
October 18, 2006, 16:14 |
thankyou Jason. I will try this.
Amer |
October 28, 2019, 08:34 |
#4 | |
Rep Power: 9 |
didnt work for 18.1 |
Help, about periodic condition | caohan | FLUENT | 6 | September 20, 2013 03:14 |
Quarter Burner mesh with periosic condition | SamCanuck | FLUENT | 2 | August 31, 2011 11:34 |
UDF problem with Parallel Solver | manu | FLUENT | 0 | January 24, 2008 14:31 |
Periodic boundary condition & Unsteady flow | Somchai | FLUENT | 2 | March 28, 2006 08:51 |
periodic boundary condition | tucker | FLUENT | 3 | May 23, 2005 06:56 |
