Is there a command that can be used in a Gambit jouranl that allows all entites to be selected.
Something like: volume create translate allfaces vector 0 0 20 |
Hi Andrew,
i know that you can use the below command to move all faces (in this case three faces) by a vector. face move "face.1" "face.2" "face.3" offset 0 0 20 is this what you are meaning? |
#3 | |
$f_select=LISTENTITY(t_fa) would select all faces in domain $f_select_associated=LISTENTITY(t_fa,t_vo,"volume. 1") would select all faces associated with volume volume.1. calemarie |
gambit journal for run a journal? | Ralf Schmidt | FLUENT | 3 | May 25, 2010 14:41 |
Gambit Journal file descrpencies | Aloe | FLUENT | 0 | January 6, 2009 16:13 |
running gambit journal step by step | giogio | FLUENT | 1 | March 10, 2008 14:03 |
Journal files of Gambit & Fluent | Arif Saputra | FLUENT | 6 | September 10, 2001 04:29 |
Gambit Journal File Scripts, Public Database Needed? | Jonas Larsson | Main CFD Forum | 13 | March 2, 1999 07:25 |
