baseball trouble
Old   November 3, 2006, 00:02
Default baseball trouble
skander
Hi all, Some of you may have been following my troubles, curious what else you have to say. I am continuing to pursue the solution to my baseball problem, however I cannot seem to make the flow actually flow around the ball, it seems to go straight through it, the ball has no effect on the field flow. I have defined the ball with a wall boundary condition, and everything that I am doing makes sense. My duct is 120x60x60, my ball has radius 2. Velocity inlet is 20m/s and I use air, ideal gas as the fluid. Pressure at the pressure outlet is zero. In addition, I occasionally (not always) get the following error: Error: divergence detected in AMG solver: temperature Error Object: () I realize I am a beginner at this, however, I really don't think this should be this hard. I use the default solver settings with Spalart-Almaras viscousity, nothing special. Any advice for a novice would be appreciated.
Old   November 3, 2006, 02:51
Default Re: baseball trouble
Razvan
With your permission, I could prepare a sample case for you, so you should be able to figure it out yourself. Is that OK?
Razvan
Old   November 3, 2006, 05:49
sam
1 Use coupled solver. 2. Courant number intially to 0.5 3. First order upwind then switch to 2nd order upwind.
thats all.
If problem still exists write more detials with new configuration
regards
Old   November 3, 2006, 07:34
Michael B
Try this mesh. It should work fine. I'm running it at the moment. (I was curious on the case)
http://www.yousendit.com/transfer.ph...id=OTT+GvabQa8=
Michael Bo
Old   November 3, 2006, 11:57
skander
Razvan, if you have the time and the heart, I really appreciate it. Thank you. You can email me at s-spies-1@northwestern.edu best Skander
Old   November 3, 2006, 15:55
Razvan
I sent you something at that mail adress. I hope it will be of real help to you.
Razvan
trouble with `pressureDirectedInletVelocity' yohey OpenFOAM Running, Solving & CFD 2 October 4, 2013 11:15
[ICEM] trouble with mesh quality from ICEM in CFX Solver escher25 ANSYS Meshing & Geometry 0 February 28, 2011 07:38
[GAMBIT] Trouble meshing complex VOF geometry RPJones ANSYS Meshing & Geometry 2 February 14, 2011 18:54
Finned Pipe Trouble fabioxyz CFX 8 August 31, 2009 02:20
trouble with squeezing mesh adrianahscott OpenFOAM Running, Solving & CFD 0 August 29, 2009 07:25
