November 13, 2006, 07:21 |
gas reaction
1. I compute two-step reactions. 4 POCl3 + 3 O2 â†' 2 P2O5 + 6 Cl2 2 P2O5 + 5 Si â†' 4 P + 5 SiO2 My data for calculation the reaction rate are : "pre-exponential factor : 1e+15", "activation energy:1000" and "temperature exponent:2.44"。 (are these values too large?). But FLUENT says "Error: Gauss_Elimination: singular matrix. Error Object: () ". What's wrong with my two-step reactions?
2. (1) For species transport, how can I search the data of Lennard-Jones(L-J). Does anybody have any recommend? (2) First, "MATERIAL TYPE" for fluid, I give all fluid properties to be constant. Second, "MATERIAL TYPE" for mixture, I set "MASS DIFFUSIVITY" to "KINETIC THEORY". Then, unlikely before fluid properties option will appear "L-J Characteristic Length" and "L-J Energy Parameter". Why do they appear ?? Are "L-J Characteristic Length" and "L-J Energy Parameter" calculated by FLUENT ?? If yes, which equation can be presented the computing process ?? |
November 18, 2006, 11:15 |
Re: gas reaction
can somebody give him some suggestion ?
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Segmentation fault in running alternateSteadyReactingFoam,why? | NewKid | OpenFOAM | 18 | January 20, 2011 16:55 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 08:56 |
Gas pressure question | Dan Moskal | Main CFD Forum | 0 | October 24, 2002 22:02 |
chemical reaction - decompostition | La S. Hyuck | CFX | 1 | May 23, 2001 00:07 |
