Gambit: Valid entity doesn't exist
Old   December 11, 2006, 03:34
Default Gambit: Valid entity doesn't exist
Sharon
I defined the boundary types that I wanted but the warning error showed:Boundary entity does not contain any valid entity and is not written. These are the faces that I defined as wall in a volume that I created.
If I were to define the faces as a solid continuum will it be the same?
Most of the tutorial that I had come across are those that doesn't have any objects in the volume created. Is there any tutorial which model something similiar to it??
Errors during exporting from Gambit to Fluent redrum FLUENT 3 August 6, 2014 22:40
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 13:43
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
WHY NON-POSITIVE FACE AREA EXIST IN GAMBIT? MAHBUB FLUENT 0 November 26, 2007 01:16
query on valid entity Sharon FLUENT 5 October 16, 2006 05:29
