Does Fluent 6.3 LINUX64 run on EMT64 processors? |
I.e. will it run on the Cloverton/Kentsfield chips without patching???
It should run on either RedHat Enterprise 3/4 and SuSE because they are tested and certified. But I also have problems getting it to run. I am running openSuSE 10.2 64bit. The tech support told me it has something to do with the Motif shared files but I havent figure it out. Are you having the same problem? Please show me if you manage to make it to run.
Check your email!
Rocks 5.4 Rsh Connection Refused for Fluent 6.3 | bucnikf90 | Hardware | 2 | March 29, 2012 16:24 |
Parallel run in fluent for multiphase flow | apurv | FLUENT | 2 | August 3, 2011 19:44 |
Validation 12.1 vs 6.3, Difference in Reported Inlet Total Pressure | jola | FLUENT | 1 | May 5, 2011 14:33 |
Mesh modifications in fluent 6.3 | samygero | FLUENT | 0 | November 29, 2010 04:59 |
Common issue - Mesh generation tool for Fluent 6.3 64-bit | AMusteykis | FLUENT | 4 | March 22, 2010 12:03 |
