HiFriends I am a new user and learning FLUENT..I like to know what is CFL number and its importance. What is the criteria to define time step size(s), number of time step and number of iteration per time step. I am studying atomization please send me appropriate information thanks in advance vivek
Dear Vivek,
The Boundary information waves should not cross morethan one grid space per unit time. If you consider some big timestep, then Boundary information will propagate or move many grid cells in a timestep and finally you cant get correct flux entering or leaving through each cell face. The information wave speed is based on fluid velocity and the velocity of sound max u+c ... so your timestep mustbe less than (delx or cell size)/u+c. If you select some big timesize, then discretize that into number of subiterations. Hope it will help you. |
Mubassh is correct if you are solving with coupled/explicit solver. If you on the other hand are using the implict solver you will be able to use CFL-number (=U*dt/dx) higher than 1. As stated by Fluent, solving the flow with new NITA scheme (6.2) you may under fortunately circumstances be able reach CFL-numbers of 100!
CFL number in steady simulations | Rol | Main CFD Forum | 4 | August 20, 2010 09:17 |
CFL number for Navier-Stokes (Infinite? How large?) | gory | Main CFD Forum | 6 | April 30, 2009 19:51 |
sonic Jet in crossflow (slot injection), cfl no | amol palekar | Main CFD Forum | 1 | November 14, 2004 20:46 |
implementing the CFL criterion | Ben Houston | Main CFD Forum | 1 | December 4, 2002 10:16 |
CFL limits for separated flow | Bigarella | Main CFD Forum | 3 | August 11, 2002 07:22 |
