convergence in 3D turbulent flow
Old   February 13, 2007, 06:50
Default convergence in 3D turbulent flow
Amel
hi ! I works on a metalurgical tundish, the turbulent flow 3D of liquid steel at high temperature. my problem is that the solution converged in more less than 100 itérations !!, I haven't found why, can you please help me. thanks
Old   February 13, 2007, 10:28
Default Re: convergence in 3D turbulent flow
Rizwan
can u please elobarate? in more less than 100, wat do u mean exactly/?
Old   February 13, 2007, 12:16
Amel
hi Rizwan, I want to say that the simulation was for a 3D geometry of a metallurgical tundish ( it is a bath of liquid steel) the problem is that for a k-& model of turbulence, for my boundary conditions and for my grid of about 1 million of cells , the calculation converges in few itérations , like 27 itérations !!! and in some cases I tried it converges in 160 itérations. I want to know what may be the problem in my configuration. thank you for your help.
Old   February 13, 2007, 12:48
Rizwan
what is the convergence criteria u r using? if its 1e-3 i sugesst u use 1e-6 and use double precision. if its steady case, i strongly feel u have to look at ur problem once again.
Regards
Old   February 14, 2007, 05:45
Amel
yes, I will change criteria and I will see if the problem disappears, thanks for help
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
mass flow convergence on interfaces Tatiana STAR-CCM+ 0 June 25, 2009 03:19
Weak rotational flow - Convergence Problems Daggemann FLUENT 1 May 8, 2009 09:45
Convergence in Flow between corotating disks Felipe FLUENT 7 January 27, 2004 10:20
Turbulent steady flow around a circular cylinder Mirek Kabacinski FLUENT 0 July 23, 2003 18:40
