surface monitor file
Old   February 23, 2007, 05:07
Default surface monitor file
emanuele
hello.
I want to monitor mass average of a field variable on a surface at the end of each time step in my fluent model. So i use the surface monitor panel and i plot the data and write them to a file. The problem is that if i want to open this file, loading it in solution xy plot or in file xy plot, Fluent send me a message " file not found " altough the file exists! ( name_of_file.out ) Why? How can i open the file ?
Thanks
Old   February 23, 2007, 15:09
Default Re: surface monitor file
Sri
Did you try to open this with Excel?
Old   February 28, 2007, 04:48
ice
which version of fluent do u have, Fluent v6.2 Widows?
I think, it is a bug in this version, U can try to plot a xy-file in Linux or in newest window's Version v6.3, there is no such problem
[ICEM] Problems with coedge curves and surfaces tommymoose ANSYS Meshing & Geometry 6 December 1, 2020 11:12
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible velan OpenFOAM Meshing & Mesh Conversion 3 October 22, 2015 11:05
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
[Gmsh] boundaries with gmshToFoam‏ ouafa OpenFOAM Meshing & Mesh Conversion 7 May 21, 2010 12:43
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
