Graphic Problem with ATI Radeon 9600 / 9700
Old   February 24, 2007, 04:12
Default Graphic Problem with ATI Radeon 9600 / 9700
Kamenos Xanthi
Hello, I have tried to install Fluent 6.1 on my Laptop but unfortunately it isn't working.I understood, that there is no compatipility between my Graphic Card and the Program FLUENT. Actually, I can start the Program and do the Pre-Processing and the Solution without any Problem. But when I start the Post-Processing and want to open the Graphics Window, I get a white Secreen and an Erorr in Fluent "Error: Floatin Point error: divide by zero". "Error object)".
I saw the old version of the same problem but I can't find the answer.. (http://www.cfd-online.com/Forum/flue...cgi/read/28442)
Thanks
Kamenos Xanthi
Old   February 25, 2007, 07:46
Default Re: Graphic Problem with ATI Radeon 9600 / 9700
Kamenos Xanthi
So, could you give me any solutions to my problem? Is there any crack available?
Thanks Again
Kamenos Xanthi
Old   February 26, 2007, 10:51
Dr. Flow Squad
try updating your graphics card driver. that worked in my case.
Problem with viewing graphic view when running in UNIX pitisrisuk Main CFD Forum 1 April 15, 2016 11:39
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 05:59
graphic problem chiccopeso CFX 8 June 7, 2010 07:18
I have a problem with GridgenV15 graphic display Carlo ANSYS Meshing & Geometry 1 April 11, 2009 14:33
Graphic Problem with ATI Radeon 9600 / 9700 peter hess FLUENT 1 June 8, 2005 09:42
