compressible / incompressible?
Old   February 28, 2007, 08:24
Default compressible / incompressible?
P.
I've written an UDF to direcly link the material density to it's temperature. It is supposed to be an laminair incompressible fluid. When I display the temperature and the densisty, to my knowledge these two should be identical. But although they look almost the same they are not a perfect match.
My guess is Fluent is modeling it like a compressible fluid, hence the small densisty differences.
Can you explain to me what I'm overlooking or should change in Fluent?
Regards,
P.
Old   February 28, 2007, 09:06
Default Re: compressible / incompressible?
Pratik Mehta
hi , u have seemed to use a UDF in which density is a function of a temperature , right , so u will see some difference in the two plots of temperature and density. R u lookin for natural convection case ? As far as my knowledge is concerned , u cannot comment on a flow ( u have mentioned fluid , did u meant flow ?)compressible or incompressible depending on just density variation with temperature , which i mention is a case of a pure natural convection case , where the flow is still modelled as incompressible
I think fluent is correct in its representation as far as u r lookin for convection case, let me what u think of
regards pratik
compressible and incompressible flow chinababu FLUENT 4 November 13, 2008 05:56
Can a compressible solver solve incompressible ? jinwon park Main CFD Forum 17 December 13, 2007 05:00
Compressible -> incompressible. Jinwon Main CFD Forum 6 November 23, 2007 21:07
Incompressible and compressible flow. John. Main CFD Forum 1 December 15, 2004 11:29
Compressible vs. Incompressible formulations Fernando Velasco Hurtado Main CFD Forum 3 January 7, 2000 16:51
