PLS help me find the error in the code.
Old   March 3, 2007, 04:21
Default PLS help me find the error in the code.
arwang
Dear freind:
The following code is used to compute the sum pressure on two walls which will be applied on the other outlet. when I compile it,prompting the warning in console window like that:
..\..\src\wallpre.c(10) : warning C4700: local variable 'd' used without having been initialized
Could you have a good ideal to solute the problem.I don't know whether the code can realize my thought to apply the sum pressure.
Code following:
#include "udf.h" real calc_pressure() {
real pressure;
face_t f;
int w_id0=6;
int w_id1=7;
real totalpressure;
Domain *d;
Thread *t1 = Lookup_Thread(d,w_id0);
Thread *t2 = Lookup_Thread(d,w_id1);
real sum0_a,sum0_f,sum0_p,sum1_a,sum1_f,sum1_p,force;
sum0_a=sum0_f=sum0_p=0;
sum1_a=sum1_f=sum1_p=0;
begin_f_loop(f,t1)
real aa[1],area;
F_AREA(aa,f,t1);
area=NV_MAG(aa);
sum0_a+=area;
force=F_P(f,t1)*aa[1];
sum0_f+=force;
sum0_p+=sum0_f/sum0_a;
end_f_loop(f,t1)
begin_f_loop(f,t2)
real aa[1],area;
F_AREA(aa,f,t2);
area=NV_MAG(aa);
force=F_P(f,t2)*aa[1];
sum1_a+=area;
sum1_f+=force;
sum1_p+=sum1_f/sum1_a;
end_f_loop(f,t2)
totalpressure=sum0_p+sum1_p;
return totalpressure; } DEFINE_ON_DEMAND(get) {
Domain *d;
d = Get_Domain(1); } DEFINE_PROFILE(outpressure,thread,position) {
real pressure;
face_t f;
pressure = calc_pressure();
begin_f_loop(f,thread)
F_PROFILE(f,thread,position) = pressure;
end_f_loop(f,thread) }
Old   March 3, 2007, 04:26
Default Re: PLS help me find the error in the code.
arwang
Pwall1+Pwall2-->Poutlet wall1 id = 6 wall2 id = 7
how to set the Domain initial value.
Who can find me this fortran code 'CHEMR'? Dong Ye Main CFD Forum 1 October 13, 2005 17:02
where to find code for nearest wall distance Frank Main CFD Forum 1 July 5, 2005 10:07
What is the Better Way to Do CFD? John C. Chien Main CFD Forum 54 April 23, 2001 08:10
user friendly cfd code waqar Main CFD Forum 19 August 18, 2000 16:31
Open source CFD code development, possible? Dr. Yazid Bindar Main CFD Forum 27 July 18, 2000 00:18
