color contours with black line edges
Old   March 21, 2007, 12:07
Default color contours with black line edges
Anish
I need your help in plotting the contours with black edge lines in FLUENT. Contours seperated by black edge lines.
Your quick help is very much needed for my report preparation.
Please add some tips in grabbing good quality pictures direclty from FLUENT
I have increased the text size from default value. I'm expecting the quality of the pictures to further improve with above procedure.
Thanks in advance Anish, IIT Madras
Old   March 21, 2007, 12:08
Default Re: color contours with black line edges *NM*
Anish
Old   March 28, 2007, 01:02
aja
Try to draw filled contours, after that switch Display/Scene/Overlays and now use only lines instead of filled contours. The appropriate min and max values are necessarry.
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 flakid OpenFOAM Installation 16 December 28, 2010 08:48
Regarding FoamX running Kindly help out hariya03 OpenFOAM Pre-Processing 0 April 18, 2008 04:26
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 15:16
