How to simulate a large scale body?
Old   March 27, 2007, 15:29
Default How to simulate a large scale body?
stefanie
Hi there, I want to simulate the ventilation and heat transfer in a very large building. I want to know how to make a small model using FLUENT? What principle should be used to diminish the large body to a small model? Thanks.
stefanie
Old   March 28, 2007, 16:48
Default Re: How to simulate a large scale body?
Seyed Farid Hosseinizadeh
Hey: I did this work before. You just need to know waht is your Rayliegh Number, Reynolds Number, Prandtle number. That's it you can make it. You just need to fix these numbers. If they are fixed you are solving the same problem. Don't worry you can apply the real dimension but play with material properties to fix these numbers. Let me know if you still have a problem. Thanks/Farid
Old   March 29, 2007, 12:19
stefanie
Thanks Farid, I got it.
Full scale or reduced scale CCi Main CFD Forum 0 July 11, 2009 10:31
About Large Scale Domains Swarup FLUENT 10 October 4, 2006 23:09
scale or full scale justin FLUENT 1 August 4, 2006 22:00
Free surface and moving body Steve FLUENT 0 August 18, 2004 02:54
SIMULATE A THOTTLE BODY Pierre Rutten FLUENT 0 March 7, 2002 09:29
