Linking two meshes
Old   March 30, 2007, 15:01
Default Linking two meshes
Geoffroy Chaussonnet
I want to mesh a streamlined body with Gambit, and i've been advised to use a structural "O-grid". In order to achieve that, i want to link two mesh with diferrent cell size on one surface. This can be asked this way "how to create a surface on which 2 different meshes exist, one is connected to coarse volume mesh (top part) and the other is linked to a fine volume mesh (bottom part).
|coarse mesh
|-----------------| <- This face MUST links 2 different size meshes
|fine mesh
Thank you in advance !!
Geoffroy
Old   March 30, 2007, 21:05
Default Re: Linking two meshes
HSeldon
Hi, In order to do that, you have to use non-conformal mesh. Supposse that you have created 2 volumes and extracted one from another. When you do this, you have to check the "remain" option in the boolean command in Gambit. That will give you the same face twice. Then, you have to set´em as interface in Gambit and then create that interface in Fluent. Go for the sliding mesh theory in Fluent´s docs, there you´ll see the concept I wrote more clearly than my english
Hope this helps you!
Old   March 31, 2007, 13:00
Thank you for you answer !
I have already tried to define the boundary as an interface with Gambit, and then couple the 2 different interfaces with the "Grid interface" menu in Fluent. But it does not work 'cause when you couple the 2 interaces, fluent create a WALL. And i want some fluid getting THROUGH the interface, as if both volumes was only one fluid volume.
So, the problem is for me still unsolved...
Old   April 6, 2007, 04:59
Okay, I just had to read the Fluent User Guide... :P My mistake was to check the "coupled" box in the "grid interface" window. The coupled option has to be used in case of Solid/Fluid interface...
[Technical] Automatic Mesh Refinement and Tetrahedral Meshes philippose OpenFOAM Meshing & Mesh Conversion 8 May 21, 2016 15:44
Getting prism to inflate into mixed tet-hex meshes Joe CFX 16 October 10, 2011 07:06
OpenFOAM with Cygwin kitchener OpenFOAM Installation 6 April 24, 2006 23:09
Hard Linking Face Meshes ?? Prateep Chatterjee FLUENT 1 July 18, 2000 17:33
Large 3D tetrahedral meshes Aldo Bonfiglioli Main CFD Forum 4 August 27, 1999 03:33
