The Realizable k-e Model
Old   April 2, 2007, 11:09
Default The Realizable k-e Model
Sevcan
If I ask "Why The Realizable k-e Model?" What is your answer?
Best whishes. Sevcan
Old   April 3, 2007, 12:44
Default Re: The Realizable k-e Model
A A S
"Realizable" actually implies that the model satisfies specific constraints on the reynold's stresses that make the model more consistent with the physics of turbulent flows and hence more accurate than the standard k-eps model.
Regards A A S
Old   April 4, 2007, 10:32
Brian
Practically though, the real difference is that Realizable is better with separating flows (Standard k-e is notoriously for overpredicting the size of separation bubbles) and generally doesn't overpredict the production of turbulent viscosity as badly. It's about 15% more computationally expensive though.
Old   April 5, 2007, 10:41
Bak_Flow
Brian,
don't you mean UNDERpredicting the size (and onset) of separation!
Where do you get the 15% more computationally expensive figure from?
Regards,
Bak_Flow
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 05:36
about Subgrid-scale model impecca OpenFOAM Running, Solving & CFD 4 December 20, 2013 10:36
Low Reynolds k-epsilon model YJZ ANSYS 1 August 20, 2010 13:57
LES and combustion model Margherita Cadorin CFX 0 October 29, 2008 05:24
Advanced Turbulence Modeling in Fluent, Realizable k-epsilon Model Jonas Larsson FLUENT 5 March 13, 2000 03:27
