BLayer
Old   April 9, 2007, 11:46
Default BLayer
nick
Hello, I'm trying to attach a BL mesh to a surface but the arrow points out of the domain volume and therefore it is improperly attached. Ho to make the arrow pointing into the volume? thanks
Old   April 9, 2007, 16:26
Default Re: BLayer *NM*
nathan
Old   April 9, 2007, 16:28
Default Re: BLayer
nathan
Hi, I'm new to CFD really. I found that the BL mesh will only face into surfaces that you have made. I had to split my domain up into smaller sections in order to have the BL mesh facing away from my object into the domain. Hope this help. Sorry if I'm wrong. Nathan
Old   April 9, 2007, 20:59
Default Re: BLayer
ligang zheng
click midkey of your keyboard
Old   April 10, 2007, 09:21
Default Re: BLayer
nick
thanks. if you mean the middle mouse botton, it does change the surface on which attach the BL but not the direction of the arrow, which points out of the volume, therefore I cannot even see the preview of the BL before applying it. there is only one volume domain and it has convex and concave boundaries. any other advice?
Old   April 10, 2007, 11:47
Default Re: BLayer
nick
problem solved, there was an error importing the iges file, which I fixed using the Heal option.
ICEM 2D tetra mesh question kawamatt2 ANSYS Meshing & Geometry 18 March 3, 2014 10:56
[ICEM] Unstructure Meshing Around Imported Plot3D Structured Mesh ICEM kawamatt2 ANSYS Meshing & Geometry 17 December 20, 2011 11:45
[ICEM] Can’t get 2D Blayer in hex mesh to be accurate O-block around airfoil josip76 ANSYS Meshing & Geometry 2 June 4, 2011 18:03
