Hi users, I am modelling a 2D gas flow over a catalytic layer where steam reforming takes place. For getting the reactions in the catalyst I have written an UDF (3 global reactions with some kinetic parameters). The problem that I am facing is that sometimes I do not have any problems when I turned on the reaction and sometimes I run into the following error: Floating point error: invalid number. Any suggestion how to overcome that problem? Before I hooked on the UDF I have done some iterations until I got a stable flow in the reactor and I have lowered the URF for each species to 0.5.
Thanx for your help! Claud |
try a different number type for your variables.(ie. int,real,float,double)
A simple UDF question | Pirooz Darabi | FLUENT | 0 | October 31, 2007 15:22 |
Basic question: UDF for wall heat flux | Carl | FLUENT | 1 | August 5, 2006 19:01 |
Question about UDF | summer | FLUENT | 1 | July 18, 2006 10:13 |
UDF question | Ryan | FLUENT | 2 | July 5, 2006 14:54 |
A question about the dynamic mesh UDF | Tango | FLUENT | 1 | November 27, 2003 02:56 |
