April 26, 2007, 12:01 |
Porous Outlet
I have to simulate an Porous outlet (which simply a rectangle ). I have thinking to define the porous media feature (as I read in some mails in the forum) but the problem I can't define a thin volume in front of my outlet whihc would act as the porous media. I was thinking to define the outlet as an "exhaust fan" . Can be it used with an inlet_velocity ?. This outlet is filtering 40% of the flow , How should I set the pressure jump ? Thx for any help PK |
April 26, 2007, 12:53 |
Re: Porous Outlet
You should be able to create the porous continum zone in Gambit for the filter, and specify a pressure drop. Then just take the two faces which would exist around the porous zone and group this together into another fluid continum zone.
Porous media setup issues in Fluent | Bernard Van | FLUENT | 29 | January 26, 2017 04:09 |
Modelling Combustion in Porous Zone | tanjinjack | FLUENT | 2 | September 26, 2016 04:10 |
Compressible flow, no data at the outlet | mireis | FLUENT | 6 | September 3, 2015 02:10 |
modelling a porous wall as outlet | Swen | FLUENT | 3 | July 10, 2011 07:42 |
VOF Outlet boundary condition in cfd - ace | JM | Main CFD Forum | 0 | December 15, 2006 08:07 |
