regarding vof model
Old   May 16, 2007, 08:43
Default regarding vof model
Garima Chaudhary
Hi all, i tried this vof model given in fluent tutorial ,problem referred as 16 with the a geometry of cylinder of height 2 m and radius 1 m , I tried in the same way as given in the tutorial example with axisymmetric swirl case with the same settings what it has been mentioned in the tutorial problem but I get an error of grid check failed after I build the case on the mesh exported from gambit , If i do grid check only on the imported file from gambit I dont find any grid check problem but once i build case on it , i get this problem ,
my geometry specifications: symmetry wall default interior as fluid pressure outlet at the top
mesh specifications : interval size as .01 quad map default
zones and boundaries: symmetry fluid throughout the volume pressure_outlet at the top wall
i can send the cas and the msh file if u want , i will be highly obliged if u kindly look into the problem.
with regards Garima
Old   May 16, 2007, 14:16
Default Re: regarding vof model
ravi
hi garima
can u send the mesh file to this id
i will try to verify
bye
VOF Model or Mixture Model mems21 FLUENT 2 March 9, 2010 10:37
A Problem with setting the time step in VOF model Le FLUENT 2 July 20, 2006 22:00
free surface of VOF and melting model? wanghong FLUENT 3 March 13, 2006 09:57
help needed for vof model yan FLUENT 3 December 16, 2005 01:17
Moving mesh or VOF? Giovanni Main CFD Forum 16 September 24, 2001 08:25
