outlet boundary condition
Old   June 6, 2007, 21:14
Default outlet boundary condition
Brian
What outlet would I use with a mass-flow inlet in a mixed convection problem where I use the incompressible ideal gas law? The fluent manual says outflow can't be used with varying density.
thanks
Old   June 7, 2007, 16:55
Default Re: outlet boundary condition
Prasad Dudhgaonkar
Try using pressure outlet. In most cases it's value is known or can be measured easily.
Old   June 7, 2007, 18:16
brian
What exactly does a pressure outlet in this situation impose on the model? By changing pressures at this outlet it can't 'pull' more mass or slow the inflow into the domain, since the mass inlet is fixed and it is incompressible?? Or does it just affect the pressure in the domain, but does this affect the outlet flowrate? can it affect the mass flowrate out of the domain? thanks
Old   June 20, 2007, 07:24
maryam fallah
when and why we must assume that the second normal derivative of pressure is zero at outlet
Outlet Pressure-flow coupled boundary condition (Windkessel) cfdfsi Fluent UDF and Scheme Programming 3 July 21, 2017 12:30
Boundary Condition outlet natantyt FLUENT 0 September 27, 2010 15:30
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
inlet and outlet boundary condition for turbomachinery solution siamak1424 OpenFOAM 2 August 15, 2009 11:14
Outlet boundary condition CN FLUENT 6 May 22, 2005 09:37
