buoyancy driven flows
Old   June 7, 2007, 20:43
Default buoyancy driven flows
brian
My model is a vertical downflow model. I have a mass flow inlet at the top. In it the heat flux from the walls is great enough so natural convection occurs. I suspect the overall flow through the domain is constant, but there will be areas of recirculation near the hot walls.
My question is what outlet do I use? Fluent says not to use outflow for varying density flows. So I would suspect pressure outlet, but what does this impose?
I understand if I were to use pressure inlet and pressure outlet, by varying the DP in the domain, I'd vary the flowrate, but when i've already set the mass inlet flowrate, how does varying the pressure outlet affect the model? Thanks
Old   June 8, 2007, 15:17
Default Re: buoyancy driven flows
Sujith
The flow rate will be constant as defined in inlet boundary condition. The outlet pressure will be used as a reference pressure to calculate the pressure in the remaining part of domain, using the dp obtained by solving the governing eqns.
if you vary the output pressure, you can see that input pressure also varies such that delta P will be constant.
Old   June 20, 2007, 19:07
red lemon
For buoyancy driven flows use presto or bfw pressure scheme with incomp-ideal-gas or ideal gas with gravity on. For v.low temp ranges you can use Boussinesq for density.
continuity convergence in buoyancy driven flows brossofor FLUENT 0 March 29, 2011 04:31
Pressure correction in Buoyancy driven flows Aditya Main CFD Forum 0 March 8, 2007 06:36
Buoyancy Driven Flows Aditya Main CFD Forum 0 May 26, 2006 02:07
Buoyancy driven flows A. Guardo FLUENT 9 March 25, 2004 09:12
buoyancy driven flows anevin Main CFD Forum 2 December 31, 1998 23:56
