fluent background connection refused
Old   June 16, 2007, 11:00
Default fluent background connection refused
Reginaldo Cotto
Hi, I'm need to run Fluent in background using Linux cluster at four nodes.
I'm writting in shell:
fluent 3d â€"t4 â€"g â€"cnf=/home&hellip;/fluent.hosts < roda > output2>> errolog &
Fluent is started, but the nodes computes are refused. Could someone please suggest any alternate method to solve this problem?
Thanks in advance.
Old   June 16, 2007, 13:23
Default Re: fluent background connection refused
Vimal
I am not sure if Fluent sets the communicator by default. But from your shell command, you seem to be missing the -px option.
This is the script that I generally use (part of a PBS script).
fluent 2ddp -t$ncpus -pnmpi -cnf=pnodes -g <run.inp> run.out
Hope this helps.
Old   June 16, 2007, 13:27
Vimal
"fluent 2ddp -t$ncpus -pnmpi -cnf=pnodes -g <run.inp>out"
Old   June 17, 2007, 07:30
Reginaldo Cotto
Vimal
Thank for help.
Reginaldo
Abaqus - Fluent Coupling WITHOUT MPCCI s.mishra FLUENT 1 April 5, 2016 06:47
Rocks 5.4 Rsh Connection Refused for Fluent 6.3 bucnikf90 Hardware 2 March 29, 2012 16:24
Fluent 6.3 32bit vs Fluent 12.0 64bit ibex7 FLUENT 7 April 18, 2011 02:44
few quesions on ANSYS ICEMCFD and FLUENT Prakash.Paudel ANSYS 0 August 12, 2010 12:07
Runing the parallel version of Fluent in the background Carolin Kosiol FLUENT 0 June 26, 2000 06:09
