Gambit Cleanup
Old   July 18, 2007, 13:25
Default Gambit Cleanup
nick
I have 3 connected real volumes in GAMBIT. I use the Geometry Cleanup tool to connect duplicated vertices, edges and surfaces. After I do that the 3 volumes become virtual volumes and I cannot convert them to real, GAMBIT says that there is some other virtual lower geometry, but there isn't any. Because the volumes are now virtual I cannot perform any volume splitting which I need to proceed with the meshing. How to clean up the geometry and keep it real?
Thanks
Old   July 18, 2007, 16:17
Default Re: Gambit Cleanup
red lemon
Use Gambit 2.4 (just released) or delete the newly cleaned volume and leave lower topology. Then rebuild volumes from lower real entities by stitching.
Gambit help: Cube inside cube Jack Martinez FLUENT 13 August 11, 2010 06:29
Gambit 2.3.16, Xming or Exceed...HELP! bambam3417 FLUENT 10 May 7, 2010 12:39
Gambit -dev X11 doesn't work Ervin Amet FLUENT 0 October 28, 2007 08:33
GAMBIT: Hangup on cleanup small face smillerhh FLUENT 0 October 9, 2006 02:30
3-D Mesh Check in Gambit..... SHR FLUENT 4 March 25, 2003 03:10
