July 20, 2007, 05:24 |
Fluent Memory Problem
i get a 'out of memory.malloc_storage: unable to malloc Density' errors when i initiliaze my domain for computation in fluent. Any ideas??
July 20, 2007, 08:37 |
Re: Fluent Memory Problem
Can your problem fit into your available RAM?
July 21, 2007, 01:01 |
I am using Windows OS with 2GB of RAM of FLuent 6.3, so its hard to believe that this could be an issue. I have a mesh with apporx. 2.6 million cells. It seems that the windows OS might not be suitable for this case, so a switch to Linux is the go. Thanks for the reply!
July 22, 2007, 16:33 |
Hi You need about 1Gb RAM for each 1million cells in the mesh. So you may have reached the limit though this is dependant on model used (eg radiation and coupled solvers need more memory). For 32 bit windows you can address 2**32 bytes per node which in reality is about 2Gb. Options are use 64bit Windows/Linux and add more RAM (needs about 30% more RAM for 64 bit) or run in parallel with shared memory. For the former case you will need 64 bit compliant hardware as well (and ntx86_63/lnamd64). cheers
User Defined Memory Problem | Melih | FLUENT | 17 | February 21, 2020 07:43 |
Problem with Fluent Parallel | DarrenC | ANSYS | 0 | October 27, 2009 05:38 |
Memory allocation problem | Ammar Abdilghanie | FLUENT | 5 | February 19, 2007 18:15 |
Memory problem in Fluent | sai | FLUENT | 0 | January 30, 2007 05:32 |
How to free memory after running Fluent ? | David | FLUENT | 1 | February 27, 2004 03:59 |
