divergence detected
Old   July 20, 2007, 09:58
Default divergence detected
German Montalvo
I am working in a compressor stage, I am trying to validate the model with results of other software CFX, so replicated the whole model in terms of the geometry and boundary conditions as well initial conditions, though after a few iterations the simulations stops with the following error message "Error: divergence detected in AMG solver: temperature" I check everything over and over but seems that the problem is not there, though I noticed temperature and pressure limited in the volumes of my model. So I wonder if anyone could help me out on this in order to figure it out.
Thanks in advance.
German
Old   July 20, 2007, 10:26
Default Re: divergence detected
Joe
You cannot setup CFX and Fluent absolutely identically. There are under-the-hood differences.
Old   July 20, 2007, 10:31
German Montalvo
So there are differences beyond my control, because of the code of Fluent?
Old   July 20, 2007, 10:46
Joe
Yup.
Old   July 20, 2007, 16:18
AAA
Hey
Try lowering the under-relaxation Factor for energy to 0.5 as well as density and see if it works.
Regards
AAA
Old   July 20, 2007, 16:26
red lemon
Never lower energy to anything less than 0.98. Try disabling secondary temperature gradients, fmg initialisation, pressure based coupled solver with low CFL.
Old   July 20, 2007, 18:07
AAA
Hi Again
Red lemon is right. The energy under-relaxation factor must be between 0.95 to 1.0. What I meant was to lower it for a while to see if an initial solution can be reached, then bump it back to 1.0 for the final solution.
Sorry
AAA
Old   July 23, 2007, 08:35
German Montalvo
How I disable the secondary temperature gradients?
Old   July 23, 2007, 18:08
red lemon
Type this into the window : (rpsetvar 'temperature/secondary-gradient? #f)
Old   July 24, 2007, 07:49
German Montalvo
Under which menu?, because I typed into the window, but does not recognize the command.
Old   July 24, 2007, 13:50
  #11
red lemon
Type the entire line including brackets into the Fluent windows and hit return. This will disable them and make the solution more stable.
Divergence detected in AMG solver: ads-0 Patrino FLUENT 6 May 12, 2022 03:11
Quarter Burner mesh with periosic condition SamCanuck FLUENT 2 August 31, 2011 11:34
Divergence detected when using parallel solver Phil FLUENT 3 May 9, 2008 08:17
user subroutine error CFDUSER CFX 2 December 9, 2006 06:31
user defined function cfduser CFX 0 April 29, 2006 10:58
