Pressure jump on supersonic velocity inlet
Old   August 9, 2007, 00:23
Default Pressure jump on supersonic velocity inlet
Viktor
I have supersonic velocity inlet with two gases of different densities. Both gases have the same static pressure and velocity. First issue is that Fluent only stable with 1st order scheme. Second, on the inlet in the point separating two gases I have static pressure lower then prescribed. I tried prescribe total pressure and total temperature it blows up. What might be the reason and the way to avoid these problems. Thank you.
Problem with assigned inlet velocity profile as a boundary condition Ozgur_ FLUENT 5 August 25, 2015 04:58
velocity inlet vs pressure inlet cheong FLUENT 6 April 9, 2011 03:07
Pressure farfield vs Velocity Inlet BC DarrenC FLUENT 1 September 16, 2009 02:23
Setting pressure and velocity in inlet Asghari FLUENT 5 September 22, 2006 13:23
Total pressure and velocity inlet BC ff FLUENT 1 June 14, 2003 20:09
