Stagnation pressure more than 1.
Old   August 9, 2007, 04:33
Default Stagnation pressure more than 1.
hungpavn
I am checking a 2D cylinder, then, the pressure coefficient at the stagnation is more than 1.
Anyone can give a comment and how to overcome it, thanks in advance.
Old   August 9, 2007, 04:35
Default Re: Stagnation pressure more than 1.
Joe
Set the reference values correctly.
Old   August 9, 2007, 04:52
hungpavn
Thanks Joe!
I set: Area = Frontal area, density and visous are properties of the used fluid, depth =1, Length = Diameter, Veolity = free-stream.
Is that correct and enough?
Old   August 9, 2007, 06:14
farhan
I had the same problem before,for me the reference parameters were correct as well (check for your reference pressure), then I move the boundaries far from wall, atleast 20 times the cylinder diameter, before they were 10 times. then it was OK. A value of around 1.05-1.07 is accepted in fluent as it cant predict pressure well at stagnation.
Pressure BC for combustion chamber Giuki FLUENT 1 July 19, 2011 11:35
Setup/monitor points of pressure and force coefficients siw CFX 3 October 22, 2010 06:07
Does star cd takes reference pressure? monica Siemens 1 April 19, 2007 11:26
pressure gradient term in low speed flow Atit Koonsrisuk Main CFD Forum 2 January 10, 2002 10:52
Fluent-V5,Turbomachinery (stagnation pressure live its own life) Alberto Tamm Main CFD Forum 19 May 27, 1999 14:42
