Modelling a "Rolling Road" in Fluent
Old   August 11, 2007, 04:01
Default Modelling a "Rolling Road" in Fluent
Nick
Hi
I am modelling a 3D airfoil in ground effect. At the moment, to simulate a "rolling road" in Fluent where the ground plane moves with the same velocity as the input air velocity (ie. zero velocity relative to air), I have just set the ground plane as a non-stationary boundary with a translational velocity.
However, I want to get to the stage where I can model a fluctuating ground plane such as an ocean surface, under the airfoil. So the surface must not only move relative to the wing at the air speed, but I also want to set up something like a sine wave shape profile where the amplitude changes with time so that it mimicks a crude ocean surface with waves.
From what I have found out so far, I would need to use a UDF and a dynamic mesh. However, I would just like to hear from anyone who has done something like this before, if they have any hints or tips? I have 3 months to do this, part time, and I have never done any C programming before, or even used a dynamic mesh or done an unsteady sim in Fluent before. Am I biting off more than I can chew?
Old   August 11, 2007, 06:43
Default Re: Modelling a "Rolling Road" in Fluent
Joe
It shouldnt be that difficult. Search the UDF manual for the string "boundary deformation". A google search on "boundary deformation fluent" will probably also be worthwhile.
Ferrofluid flow modelling in fluent Souviktor FLUENT 1 January 10, 2016 04:21
Dynamic mesh in Fluent to study tire in contact with road surface lihuang FLUENT 10 March 8, 2011 10:21
fluent multiphase modelling thinktank FLUENT 0 November 28, 2009 13:41
Need Help on Fluent Modelling Laminar on BluffBody ary Main CFD Forum 1 May 19, 2005 05:59
multi phase modelling in fluent naren FLUENT 1 January 25, 2005 12:31
